cleaning solder droppings
  • cleaning solder droppings
    anyone have any tips on removing solder droppings from the panted cases of hot water boilers. most of it easily scratches off using fingernails, but there must be a better way to do this without harning the painted surface the droppings are adhered to. any suggestions would be appreciated. thanks.
    Re: cleaning solder droppings
    of course the issue is not to get solder on the tank in the first place. i always use a damp rag under the joints i'm soldering to prevent what you have.
    i would try a sharp putty knife or scratch awl and see if you can pick it off. it will and has already damaged the painted finish.
      i use the flat end of my wood carpenter pencil and push it right off with no scratches
        Use the cover to your role of teflon tape. Just place it on top and move it back and forth.
          also what works is a scrap piece of carpet, no splashes of solder and it catches flux too. Removeing the solder shrapnel. use anything that isnt abrasive or sharp like above stated
          if u cant bedazzle em with briliance, baffle em with bulls&*t
            We always use drop cloths to cover mechanical equipment during the installation.
              That's a good one,I'm going to try it on the next one.
                i am happy to report that the painted cases of the boiler with the solder spashes has not been permenantly damaged. and the winner of the best removal suggestion is... hvac hawk. the flat end of a carpenters pencil works very well. next time, in addition to protecting horizontal surfaces, vertical surfaces will be similarly protected.
                  I made the mistake of not protecting walls on a couple of occassions thank goodness it only costed me 30 extra minutes of cleanup.Can't imagine having to explain to a client that I need to know their custom color paint number.
                    Air chisel ,works for me
                      Sounds good,I'll try it next time I have to remove solder from a gold leaf mural
                        thank you
                          One more thing,Dirty. I pin stripe flames on the whole jacket with My air chisel,distracts the globes of solder!
                              Get 5 pounds of axle grease and spread it about an 1" thick across the surface you're soldering above on.
                              The solder will gently fall down onto the grease, burn a little into it but never make it to the painted surface.
                              Apply grease to hair for that man shine your wife enjoys.
