water heater with recirc retrofit
  • water heater with recirc retrofit
    This is a job I did the other day, this and finish on a bathroom I roughed in a month ago, when the bath is done, I will post. This house is built off a hill, this is the space between floors, I had to remove a 40 and go up the stairs on the side of the hill, and down with this 50, and under the stairs you see to set it in. Used type L copper, full 3/4 loop, no 1/2" isolation valves both at the furthest fixture and then the 2 you see here. Solder is a bit sloppy, sorry for that! Enjoy.
    Robert
    Re: water heater with recirc retrofit
    I love everything, but why those flexie water supplies to the water heater?
    I didn't notice an expansion tank either, is it at the main valve, or not required out there?
    And hey silly, why did you post this in the hairy homeowner section?
    Proud To Be Union!!
      Hmmm, the wife posted it in this section she had to load the pics, I don't know how to
      copper water flex are good out here, especially for the earthquakes
      expansion tank, yeah, required, but not in the habit of installing them nor are they enforced, but should be installed, you got me there. the t&p is graded and piped to the exterior though
      good going aaron!!
      Robert
        Take the unneeded union above the ball valve and put it up at the T+P.We don't want to get a bad case of the Rickets.
        Looks clean Robert
          Looks clean Robert
          yeah, I know it was not needed, but it was installed when I threw the flange pump away, you know all about that one dear Adam!!
          screw the union on the t&p, that could be construed as a code violation due to some one being able to cap it or plug it off, never a union on my t&p, call a plumber to install a coupling if it has to be cut.
          I am suprised no one commented on the 3/4 bracket clamps holding the line solid My trademark, I use those whenever I can, makes the job clean and strong. you can swing off that line now.
          No one commented on the ECO Freiendly water heater also, does that white unitrol look different to the guys back east?? It's a special cali thing.......I think, for the low nox regs...... or was that just the change to the fire box, that raised the cost $125 big ones???
          Last edited by westcoastplumber; 02-09-2008, 10:25 PM. Reason: 1st grade spelling issues
          Robert
            Nice suggestion Adam from the union on the T&P Valve Line. Quick in and out when the T&P Valve goes bad for the service guy, which will hopefully be you!
            Proud To Be Union!!
              not really a good idea Aaron, some homeowner will try to plug it from the union if it starts to leak, never give a customer the option, always hard pipe your t&p relief lines.
              Robert
                Beautiful work,You do better work than most. I also install the home comfort with manifold when re-pipe is a problem.
                  I agree to dis-agree.
                  This is what your nice looking job should of looked like.
                  Hey Robert, take a LOOK at those solder joints.
                  The only thing I wish I did different on this water heater was to leave more room for the next guy to tie the new heater in years down the line.
                  Proud To Be Union!!
                    Looks clean Robert
                    i would not install a ring/ spring loaded check valve on the inlet side of this small pump. i would install it on the outlet side. plus those isolation stops on the flange unions are a joke. after a couple of months they freeze up.
                    The only thing I wish I did different on this water heater was to leave more room for the next guy to tie the new heater in.
                    arron what happened to your unions on the inlet/ outlet of the heater?
                    also a dielectric or brass nipple would be a wise choice. even if those are dielectric nipples. also a strap on the expansion tank would be nice.
                      take that Aaron
                        adam, i need to watch the movie and eat some pie. hurry up
                          Where I am you can only use 1 elbow on the discharge from the T&P valve. It must be run straight down the side of the water heater and end no higher than 6 inches off the floor. Put simple is has to be a simple L shape with nothing fancy. In addition we must use only hard iron pipe for gas. NO flex anything.
                          This is county code for where I am.
                          I'm with Rick on installing a support strap for the expansion tank. Unless I can't see, it looks to me like it's just waiting to bust off.
                            Rick, were I work we rarely use unions on water heaters.
                            They are indeed dielectric nipples. The expansion tank is roughly 6" above the water heater, so I dis agree with the strapping idea.
                            Proud To Be Union!!
                              upc requires unions on a water heater.
                              the expansion tank is steel. the weight of the water and tank is pretty heavy for a horizontal install. vertical down. installs, no problem.
                              rick
