No 2" cast iron
  • No 2" cast iron
    I've never seen cast iron smaller than 3" here in the states. I know it's made as I installed it in Okinawa but just never seen it here. For 2" lines here, they will use galvanized.
    Re: No 2" cast iron
    What?....
      Re: No 2" cast iron
      Gear Junkie,
      We use it all the time up here in New England. Use 2" and 11/2" underground but usually switch to DWV copper once above the basement or slab.
        Re: No 2" cast iron
        Originally posted by RopeaGoat View Post
        Gear Junkie,
        What?.....
          Re: No 2" cast iron
          we have 2" cast and 1 1/2" cast at our ferg, we use it all the time in parking garages and such, commercial etc.
          You shop at home depot to much my friend.
          Robert
            Re: No 2" cast iron
            Originally posted by plumberscrack View Post
            What?.....
            What What??
            Use 1 1/2 DWV to stub out for lav drains, etc. Also will use 2" DWV for venting. There is still a 3" - 4" Cast Iron main stack but branches can be copper.
              Re: No 2" cast iron
              I'm talking about houses I've been at. Just haven't seen 2" CI anywhere.
                Re: No 2" cast iron
                We deff. have it over here.
                Proud To Be Union!!
                  Re: No 2" cast iron
                  All right, so it's settled, galvanized drain lines will always have a place in Virginia Beach.
                    Re: No 2" cast iron
                    you forgot the "in the house part" in your original post, I have seen it here before, but you are correct, mostly galvanized.....
                    Robert
                      Re: No 2" cast iron
                      See alot of 2in cast for kitchen sinks, specially in Phila. Also see galvanized, copper, and lead. Starting to see HDP to now.
                        Re: No 2" cast iron
                        Ben,
                        You need to get out more. In a lot of custom homes you are only allowed cast iron above the first floor due to noise issues.
                          Re: No 2" cast iron
                          We probably have 300' or so of 2"CI on the rack at any one time. Very common in new england. Have it both straight lengths and bell and spigot.
                            Re: No 2" cast iron
                            We have plenty of 2" Cast iron here in VA. Every supply house stocks it.
                            We use it in commercial every day.
                            Not sure what this topic is about.
                            In houses anymore, you only see 3" C.I. for stacks cause of noise. No need for 2" in a house.
                              Re: No 2" cast iron
                              Where are you at in VA?
