Meyers water pump issue
  • Meyers water pump issue
    i have a Meyers water pump on my cistern that is taking an extremely long time to pressurize the tank.
    some backgtround: the pump came with the house so it's at least 6+ years old. about 2 years ago i replaced the tank. no issues. about 6 months ago we noticed it was taking the pump longer to reach pressure. instead of around 30 seconds it was taking over a minute.occasionally there is a "chattering" sound comming from the pump.
    yesterday i timed the pumps running time and it averaged 3:24. that, to me is beyond excessive. there is no bleed down, no leaking i can find, no random running of the pump... just a looooong time to get to ~40psi.
    there is only 1 pump repair guy on island, that i can find, and he charges an arm and a leg, plus you have to bring the unit to him and leave it. this is a non deal as we will be without water during this time.
    any suggestions? inpeller? how hard to replace?
    never had a pump problem since i've lived here, except for replacing pressure switches and guages
    thanks in advance
    steve
    Re: Meyers water pump issue
    steve, if that's the case with the pump guy. then you need to purchase a replacement pump first and rebuild the bad one as a backup.
    i would first check on line for the parts breakdown and any service/ maintenance tips. see if this helps or you could purchase the parts.
    i would think that the impeller has wear or the volute is worn.
    how hard is it to purchase parts or a pump there? post a model and your price. maybe it's better to have it shipped from the states.
    rick
      generally three things are the cause. 1 the impeller is worn. 2 the jet is worn. 3, the jet and or volute are full of crap.
        thanks for the replies. i[ll get back tomorrow with some more details. beat down hard today. i swear i've met and worked for EVERY FREAKING IDIOT on St. Croix yesterday and today.
        there's a bottle of Cruzan Gold Rum with my name on it calling me like a sirene (sic?) to a wayward pirate
        g'night
        steve
          Yes, yes, and we're looking at another 4" of snow or so and then a bit of freezing rain. Screw global warming.
            Good point,make sure you stoke the stove full of them old tires to get you through the night
