moving PVC DWV
    Re: moving PVC DWV
    Where are you sitting on the plane to Ohio.I need to make sure,so I can preset the tragectory on my spitballs
    isn't that chew
      Re: moving PVC DWV
      what happens on a t-y is that when you discharge water into line it cuts off the vent as the discharge is higher than the vent.
      ________
      Vaporgenie vaporizer
      Mike
        Re: moving PVC DWV
        isn't that chew
        No Rick,
        Skoal Wintergreen Longcut has the tendency to fractate at high velocity and cause collateral damage to innocent bystanders.Depending on distance and techicality it is a toss up between tissue or even putty if I have to shoot from first class all the way back to economy
          Re: moving PVC DWV
          I'm confused again, sorry.
          Markts30 wrote:
          A combination would be easier to snake but is not code compliant as a connection from a trap arm to a drain/vnent...
          To connect the trap arm to the drain, you have to use a sanitary tee...
          A wye and 45 or combination fitting doesnot allow the proper venting...
          For a cleanout, you can put a cleanout tee below the sanitary tee in the riser..
          If I understand this correctly I do the following (I'm lost at 4):
          1 - cut out the existing t or y (whatever is in the wall).
          2 - install an new y facing to the right
          3 - install the horizontal 12" that I need
          4 - install ?? to stub back out of the wall and connect to the trap trap?
            Re: moving PVC DWV
            HUH?
            A spigoting san-tee with a clean-out above it?
            Did you know................CRACK KILLS.
            Such a great guy....So easy to tease.
            Uh Oh, Adam is flying to Philly with you Robert????
              Re: moving PVC DWV
                Re: moving PVC DWV
                Originally posted by NHMaster3015 View Post
                Thanks Hampshire,
                I have tried to explain this to plumbing contractors when I see wye and 1/8 bend used to vent a trap arm.Takes too long and usually ends nowhere.
                • #23
                  Re: moving PVC DWV
                  Sorry to be a pest to all of you but I'm not sure how to take my horizontal line out of the wall to connect to the trap. Is a 90 degree elbow ok as a couple of you have suggested?
                  Thanks,
                  • #24
                    Re: moving PVC DWV
                    Thanks,
                    Yes.
                    • #25
                      Re: moving PVC DWV
                      Thanks,
                      Yes,BUT
                      Make sure you use a long radius PVC 90.
                      • #26
                        Re: moving PVC DWV
                        Thanks again for everyone's help!
