ring by toilet
  • ring by toilet
    i have a toilet that has an orange ring on the outside of the toilet on the floor. what is causing this and how do i fix it? it has stained the cheapo linoleum so that needs to be replaced. any help would be appreciated here. thanks.
    Re: ring by toilet
    Unless the wax ring is leaking, it's usually caused by condensation.
      Re: ring by toilet
      yes i have a yellow stain and it is also by the tub so it must be water
        Re: ring by toilet
        Are you sure you didn't just miss
        I love my plumber
        "My Hero"
        Welcome, Phoebe Jacqueline!
          Re: ring by toilet
          we had a huge jobsite with 544 units. the framers used upside down orange spray paint to mark theconcrete floors for shear walls and other info.
          months after the linolium was laid, the orange bleed through the flooring.
          hope yours is not this problem.
          they had to pull all the floors and put a liner down to seal the flooring.
          not fun.
            Re: ring by toilet
            not fun.
            A couple years back we were working on a condo unit. Cement floors. The GC had sprayed the lighting, switch and outlet locations on the floor with orange spray paint. It all bled up through the lino...
              Re: ring by toilet
              no i dont miss i sit down
              just kidding i said it is out side the tub and i cant miss some thing that big
