Cast Iron pipe replacement Page Title Module
  • Cast Iron pipe replacement
    Want to educate myself. I have to replace my cast iron drain because there is a long crack (The photos attached or link here: http://www.flickr.com/photos/lmei007).
    Few questions:
    1. no more cast iron? what's the best replacement then, pvc or ...?
    2. do i need to replace the entire pipe or just cut close to its hub?
    3. how can I fix the upper portion permanently? support it from the ground or hang it via those concrete walls?
    thanks
    Re: Cast Iron pipe replacement
    Strap the wye fitting securely to the joists above or concrete wall. Remove the two sections of pipe all the way down to that cleanout at the bottom. You will have to drill or melt the lead out of that hub which won't be easy. The section that has a crack is compromised and you shouldn't reuse any of it. Install 1 piece of cast iron between the cleanout and bottom of wye. You may have to grind the nub (brain freeze..what do you call this?) off the wye to get a Fernco coupling and shear ring on. The bottom that fits into the hub should be recaulked with lead and oakum.
      The whole thing...like plumberscrack said, it will be difficult if you've never worked with hubbed cast-iron before.
        Few questions:
        thanks
        Long time no see.
        If you need to have any portion of the vertical stack replaced, you cannot use PVC under the existing cast iron.
        Unforunately, in Mass anyway, you either have to use CI, or change out the entire vertical stack to PVC from basment through roof.
          Hey DB,
          I thought homeowners weren't supposed to do any plumbing work in MA?
          At least this is what somebody else from MA always mentions (packy)
            Originally posted by DUNBAR View Post
            Hey DB,
            I fixed pipe leakage under my sink and replaced my kitchen faucet few weeks ago. I hope those are not illegal.
              I would get hold of a chain snapper (your rent all ctr has them) cut out the pipe and replace it with c.i. and no hub clamps.
                Exactly.
                Also ensure that the CI is well supported with riser clamps-ceiling and floor before cutting. You can leave them in place once done.
                  Exactly.
                  You two prefer cutting the damaged portion but not the whole piece. Like shown on the photo?
                  One more question for you guys. How can the cast iron pipe having such long crack on it? Too cold? but should no water stored inside.
                    Hey DB,
                    They're not, I'm assuming he's getting a pro for this.
                      The water tends to run on one side of the pipe. Every time someone flushes or runs water, the water runs on the same side over and over...erosion.
                      The same way that that horizontal cast-iron (or even copper drains) cracks apart at the bottom after many years.
                        Having seen the piping there, I'd suggest you get a pro.
                        If the upper cast iron shifts while you work on the lower portion you could damage other drainage/venting as well, get multiple estimates, I'm sure you'll find someone cheap.
                          I'm sure you've seen it hundreds of times, the rust usually chases down one side of the CI where the drainage most often runs...one portion in that shape usually signifies the way the rest of the drainage is as well.
                            Yeah, us service guys may not be the brightest at installing new systems, but we are sure knowledgeable about the intricacies of old plumbing systems.
                              rotflmao
