sump pump info
  • sump pump info
    Im new to the sump pump well. Everything had been working find now when I wash clothes the well fills up and over flows. The pump is working and when the pipe attached to it that runs from it to septic came off black water poured out and into the well. So do I have a clog or is the pump old and not keeping up with the water?
    jackman
    Re: sump pump info
    Ohhhhhh My... first off, the washer should not be dumping into the sump pit, and if the sump pump is dumping into the sewer or septic, it should'nt be doing that either. Call a plumber, this is not a diy job.
      Re: sump pump info
      Took the words out of my mouth. Better call a plumber. It will pay for itself to get it done right.
        Re: sump pump info
        It's possible that the pump is broken. I have no idea what kind of pump or sump pit you have, but I replaced one a while back that was sitting in small gravel. The gravel had broken the housing on the pump and it wouldn't pump anything.
          Re: sump pump info
          ok maybe i worded this wrong..where shud my washer be dumping into ? i have a sink in basement with a well or hole under it with pump in there. the pump pumps the water out of there thru some pipes that im guessing would end up in the septic mabe not.. like i said im new to this country life stuff. recently the pump doesnt seem to keep up with the water flowing from the washer ..it eventually pumps it all out tho..
            Re: sump pump info
            Have you taken the pump out of the pit an examined it?
            Might be something as simple as lint stuck in the bottom.
              Re: sump pump info
              the flow is to much for the discharge, inspect the pump and the discharge, make sure everything is clear.
              Suck out all the water, remove the pump, with the power off of course, and make sure it's all clean and good to go.
              Robert
