Vacuum breaker on a handshower.
  • Vacuum breaker on a handshower.
    Would you need a vacuum breaker on a handshower that is dependant on the diverter/water pressure to operate?
    Re: Vacuum breaker on a handshower.
    any hose, that can be submerged in the fixture or that is subject to backflow must have a vaccuum breaker on it. So technically if the handshower is installed in a shower unit (not a tub shower) and if fully extended it can not reach the water level in the shower pan, the answer is technically no. However I would not argue the point with the plumbing inspector.
      Thanks NH. I've got a new Delta whirlpool valve with a handshower. It diverts at the spout. The problem is that the Alson vacuum breaker I installed on the handshower will not allow water to pass no matter how I install it!
        Originally posted by NHMaster3015 View Post
        any hose, that can be submerged in the fixture or that is subject to backflow must have a vaccuum breaker on it. So technically if the handshower is installed in a shower unit (not a tub shower) and if fully extended it can not reach within one inch above the flood level in the shower pan, the answer is technically no. However I would not argue the point with the plumbing inspector.
        I agree
          Everything is based on the CL "Critical Level"
          The point at which a device can become submerged and backflow can occur.
            A few years back I ran into a hh shower that could actually be dropped into the toilet....
              The Acme dual purpose HH shower & toilet bowl cleaner.
