screw driver recovery
  • screw driver recovery
    How does one get a screw driver out of a cast iron sewer drain?
    Re: screw driver recovery
    Depends a bit where in the sewer drain it is
      i would like to know how it got in there
        did someone say screwed
          You could try the old magnet on a string
            [quote=NHMaster3015;132195]You could try the old magnet on a string[/quote
            a magnet will not work in a cast iron line.
              Was the screwdriver dropped down a c/o? If so, you could use a long length of twine,put a slip knot on one end,try and ease loop around screwdriver handle.A piece of pipe,or something similar will most likely be needed to both move the handle away from the pipe wall and to help tighten up the slip knot. There's aslo a chance a shop vac could be used as is or by reducing the hose down in size -may be using duct tape and pvc or other similar pipe or tubing.
              Kenneth Collier
              Maintenance and Sewer
              P.O. Box 9441
              Jackson, MS 39206
              (601) 613-2678 (Cell)
              drainman881999@yahoo.com
                a camera will either allow you to fish it out, or probably push it out to a down stream clean out or city main.
                i guess it all depends on where it's located and if it's causing an issue.
                a jetter will have an easier time to pull it back towards you.
                really need more details of the location and if you can actually see it.
                  Good Answer Rick.More details will be helpful.
                  Kenneth Collier
                  P.O. Box 9441
                  Jackson, MS 39206
                    If it is int he trap, use a magnetic grabber
                    if it is further in the drain or sewer, depending ont he size of course, it would have gone down something without a trap, use a seesnake and either a jetter or a cable to push it down.
                    doubt you want it back.
                    Robert
                      HI rick, if it is in the trap, a magnetic grabber will get it, it is tuff to keep from sticking fromt he sides, but with patience it can be done.
                      Robert
                        if it's in the trap, it's a no brainer.
                        i believe it fell in a cleanout opening.
                        steve did it right in front of me a couple months back.
                        i pushed it out to hyperion
                        i once dropped my 9'' torpedo level into an 8'' storm riser.
                        needless to say, hasta la vista baby
                        the 4 finger pick up tool is great for traps. i pulled a ring from a shower drain last year in the blind.
                          A retrieval head should be able to catch it. If it's in the (I assume 4") trap, just put your cow gloves on and reach in and grab it.
                            Is the spot where the screwdriver is accessible cause you could just cut the pipe remove the sd and reconnect the pipe. Make sure you tell everyone not to flush while you are working on the pipes.
                              Shop-vac???
