house re-plumb with wirsbo/pex info please
  • house re-plumb with wirsbo/pex info please
    I have "this old house" AKA the money pit. It was built in 1966 before building inspectors immigrated to Phoenix AZ!!!
    The house is a typical 3 bedroom ranch 2 bathrooms [one is a shower only no bath tub], kitchen, laundry room/washer no sink,
    and an additional second floor with another bathroom.
    about 2800sq ft [estimated] total
    I want/need to replace the galvanized pipe so a re-plumb is necessary.
    I plan to utilize wirsbo/pex and also have a manifold system to eliminate the toilet/shower screams. I am asking for the installer to use 3/4" throughout the house.
    I am looking for an idea as to what this may cost. I realize all jobs are unique. I do plan to do most of the dry wall repairs myself.
    Any typical/general cost range I should anticipate? I will have permits and a pro-plumber do the work. He does re-plumb homes and new construction.
    I am just looking for a price range so when he quotes a price I'll have an idea if he is fair!
    thanks
    Cactus Man
    Re: house re-plumb with wirsbo/pex info please
    Why not just get about 3 estimates from local licensed plumbers in your area. Compare what each one is proposing to do for you and make your decision based on that.
      Cactus Man, I agree with MasterPlumb.
      Rates are very area specific. You will be best served heeding his advice
        ok I understand get estimates...I know this, but that was not my question to the group...
        I'm asking for a general price range for information only
        Thus can I anticipate $3,000.00 or $12,000?????
        I'm sure there are folks on this reflector that have re-plumed a regular 1966 design house?
        I'm not looking for gold here..just an idea as to the cost range!!!
        I just want to have an idea for the budget and of course if the range of estimates run from really low to really high where they may be within the nationwide pricing.
        so how about some help here? please!
        Cactus Man
          your not gonna get what your looking for here. call three pro's thats how youll find out.
          Mike
          www.plumbinginclarkcounty.com
            I would guess anywhere from 3000-12000.
              I'd say $2,999 to $11,999.
              Proud To Be Union!!
                LOL, smartazzes
                three estimates from local companies and don't go witht he cheapest one, pick mid range.
                Robert
                  LOL
                  Thats why this board is so much fun...
                  Cactusman, unfortunately there is no way to give you what you are looking for... The price is based on your local licensed plumbers prices and their availability.
                    If your house were located here that job would fall somewhere between $5,000 and $8,000
                    cut out and remove existing galv.
                    no wall patch
                    he's a valuable member here...help the brother out
                      Good point Bill.
                      Removing the dry wall to expose the pipes, and allowing enough room to work and install the new pex would save you a decent amount of money too.
                      Proud To Be Union!!
                        thanks
                        Cactus Man
                        It sounds like he is doing it on the side so an estimate is a little tough. With you doing the drywall you are looking at around $5,000 or so.
                          You'd be looking at 8g's starting off up here.
                            THANK YOU Plumberscrack and Toutahnow!
                            That was what I was looking for. I appreciate your replies!
                            I understand the geographic differences etc. but I figured the cost of new materials and labor for the installing the new stuff and perhaps a fixture here and there [nothing fancy]
                            would run around $5000.00+/-. They can just leave the galvanized in the walls alone unless they are in the way!
                            I have already planned to repair all drywall myself. This will save some dollars I'm sure.
                            There will be one wall opened to allow access to the two bathrooms
                            I'm not sure how they will run the pex to the kitchen sink as the exterior wall is slump block
                            The second floor will be a straight run across the attic to the back wall of that bathroom.
                            Now I will also anticipate unplanned stuff but I can budget accordingly. I also now have an idea of a starting dollar figure!
                            Cactus Man
                              thanks
                              Cactus Man
                              cactus man, be careful in oversizing the branch lines from the manifold to each fixture. this is more so on the hot side as there will be a longer delay in getting hot water to the fixture since there is no circ. system.
                              i don't have the #'s right in front of me but the volume capacity of the 3/4'' per foot and 1/2'' per foot will be the difference in your wait time for hot water.
