toliet bowl
  • toliet bowl
    what's the best method to unclog a bowl or best tool?
    Re: toliet bowl
    Use a toilet auger.
    http://www.toolup.com/productinfo.as...Ridgid%2059797
    Perferably one which can extend to 6'.
    If you still can't get it, pull the toilet, lay it on it's side, send the auger through, tie a rag to the end, and pull the auger back, and whatever is in there, usually comes out.
    Proud To Be Union!!
      Re: toliet bowl
      what's the rag for?
        Re: toliet bowl
        I'll try this again...
        If you can't get it cleared while the toilet is set, pull the toilet, put it on it's side, send the auger through, tie a rag on the end of the cable, and pull the auger back.
        The rag on the end of the cable will catch anything on it's way back.
        Proud To Be Union!!
          Re: toliet bowl
          95% of the toilet stopages i come accross need only a good plunger.
          as long as the stoppage is in the toilet and not the bend. there is little chance of damaging the bowl wax.
          an auger can scratch a toilet or damage the china.
          most stopages are soft stoppages and don't involve removing a toy. if they do, then a 6' closet auger or a k-50 with 5/8'' cable and guide tube to protect the china works great.
          even on baby wipes, this works great.
            Re: toliet bowl
            I have found the fastest and most fool-proof to remove any clog from the bowl is with a 22 oz. framing hammer. A couple good hits and you can reach right in there and pull out what is causing the problem.
            Distractions are everywhere, don't lose sight of your dream.
              Re: toliet bowl
              whats a framing hammer?
                Re: toliet bowl
                elvis has just left the building.
                  Re: toliet bowl
                  I pray he's kidding. Some things you should just "accidentally" know from being on the job.
                    Re: toliet bowl
                    For me its the opposite, plungers almost never work for me because people only call me when after they've already tried the plunger. Plus they are messy. An auger is the best. Using an auger properly won't scratch any visible part of the toilet. 95% of toilet clogs I get out using an auger and very rarely ever get even a single scratch.
                      Re: toliet bowl
                      I agree with you on this but for different reason. Sometimes you plunge enough where you blow out the wax ring and now what was priced for unclogging a toilet has just been added a pull and reset toilet fee.
                        Re: toliet bowl
                        Most customers never use a plunger correctly. But, it's easier to charge for using an auger anyway.
                        By the way, JC, I've been in Elvis' bathroom and he had a framing hammer by the toilet.
