sinks
  • sinks
    what's the best way to unclog a bathroom sink?
    Re: sinks
    k39af or plunge with your hand. Thats the way I always do it but I am no plumber by any means, I just have access to good tools
      Re: sinks
      I have found that over half of bathroom sink backups are in the pop-up assembly or P-trap itself. There is a nut on the reverse side of the pop-up assembly. Once loosened the rod can be slid out of the pop-up assembly and the plunger will lift out. Remove the P-trap to check for obstructions. If it is a brass trap and the bottom of the trap feels rough now is a good time to replace it with a tubular PVC trap. Once the trap is off an easy way to clean the pop-up assembly is to push a small wad of paper towel through the drain with your plunger handle. Of course if the clog is not in the pop-up or the trap then you can proceed with a K-39 or other type of drain cleaning machine.
        Re: sinks
        I use a small electrc jetter on almost all sink lines.
          Re: sinks
          Use of K-39 or any electric jetting machine will help you greatly.
            Re: sinks
            If you want to make a huge mess, get hold of a kinetic ram
