Blanking off a toilet flange
  • Blanking off a toilet flange
    Hey there-
    I have a toilet in my basement that I wish to remove. Are there blanking plates available that I can use to cap off the line at the flange?
    Thanks.
    Re: Blanking off a toilet flange
    There are a couple of ways to do this. Sometimes the flange can be broken off and the hub cut/removed if it is PVC, allowing you to glue a cap on the pipe. I have seen people break off the flange, pack the pipe with a towel, and then concrete overtop. I would recommend leaving the flange and installing a dollar (compression) plug along with silicone if there is any chance you might use it in the future.
      call me overly accessive, but I would break up the concrete, snap cut the closet bend and install a blind plug and no hub.
      I sleep better at night knowing that in 10 years there will be no problems with stoppages, moisture under the slab or anything else.
      I have of course plugged a rag and poured plumbers dynamite in, but it was in a factory and with no warrenty.
      Robert
