no tlc here
  • no tlc here
    have you ever seen crack in cast 2"x15"not leak this is a pm question
    4"cast
    Thanks
    Re: no tlc here
    That didn't make much sense.
    If it's a horizontal run, and the crack is pointing up, then no water will hit it, there for no leak.
    It'd it's a vertical line, and the water rides the opposite side of the pipe of the crack, then no, it won't leak.
    What's a 'pm question' anyways?
    Proud To Be Union!!
      Re: no tlc here
      yes and its only a matter of time until the scale and rust let go and it will leak, do yourself a favor and cut it out and replace it or suffer the consequences.
        Re: no tlc here
        4"cast
        Thanks
        i'm picturing a 4'' horizontal line with a split on the top that's 2'' wide x 15'' long.
        yes i have. typically on a roof drain or planter box.
        we did a hotel in 1991-92 and it's all the same pipe. all installed the same time. only the planter drains are splitting. not the waste pipe.
        must be the fertilizers and lack of flushing that is the culprit
          Re: no tlc here
          I believe he means preventive maintenance Aaron
            Re: no tlc here
            Another job for J.B Weld.....
              Re: no tlc here
              you need to use duct tape too for structural stability
                Re: no tlc here
                I have actually seen a brazed repair done on a c.i. crack. Can you inagine taking that much time to clean and braze the crack rather than cut it out?
                  Re: no tlc here
                  Sometimes you have to wonder when you see some repairs. I believe often it has more to do with what they know how to do and the equipment available to them. I've seen where HO have welded leaks in galvanize pipe.
                    Re: no tlc here
                    Speaking of making do. Wait till you run across a leaking P trap repaired with bondo. Guy owns a body shop. Go figure
                      Re: no tlc here
                      LOL-Too late been there seen that.
                        Re: no tlc here
                        thanks and it might sound nuts but I'm in Tx. and the plumbing done here was fast and sloppy
                          Re: no tlc here
                          i see a lot of that here. putty, bondo, gorilla glue, West System...you name it and someone has "patched" a leak with it. sometimes it actually works
                          steve
