HWH exhaust backdrafts into furnace
  • HWH exhaust backdrafts into furnace
    My parents' HWH vent (4") is spliced into the furnace vent (9"?). When the HWH is heating, there is some backdraft into the furnace vent - despite an active vent gate controlled by the furnace - and I can feel the hot air backup and smell the burnt gas. They called the gas service and got an all-clear - no CO, normal operation was the diagnosis.
    If a little backdraft is OK, how much is OK? I still don't like it in any case.
    Any advice appreciated. Thanks.
    Re: HWH exhaust backdrafts into furnace
    It is illegal to vent two appliances into the same flue.
      Really? I have seen it many, many times, even in new homes. Water-heaters almost always share a vent with the furnace in homes I have seen.
        Not under my Codes but you have to be careful to size them properly and design them so one will not impede the other.
          Exactly, as long as its sized and fitted correctly then you can have more than one appliance on a gas flue.
            a previous home of mine had a gas fired furnace, gas fired boiler and a gas fired HWH. all were installed by a licensed plumber and inspected by the local plumbing inspector. all were vented into the same chimney. when i questioned the inspector about this, he noted that the chimney flu was large enough to accomodate the appliances. never had a backdraft problem. is this prohibtion of multi appliance venting into the same chimney a relativley recent change in codes/procedure?
              It could be done but can not be tied into the boiler flu unless the boiler flu is increased by 1/2 the size of the second appliance tie-ing into it.
              For example if the boiler's flu is 8" and the water heaters flu is 4"the common piping must be at least 10"
              8" size of the larger of the 2 flu pipes
              plus
              2" half the size of the second flu
              10" common piping required.
              If the common piping is not increased you can not dump a second appliance into the first.
                Masterplumb:
                Your reply makes the most sense to me. In this case, there is no diameter increase. Just a makeshift "Y" was created by cutting into the bigger vent pipe - it's not even a manufactured part. I don't know if any of the 4" vent pipe juts internally into the 8-9" furnace flue. The furnace was replaced about 10 yrs ago, I assume an inspector approved the work. I would be surprised. With exhaust backing up into the living space, I still cannot understand how the gas company service guy didn't measure any CO however small.
                Thanks for all the feedback.
                  I would not assume that the work was filed and inspected.
                  It may not be dumping co at this time but in the future it could very well, and I am sure you are aware of the danger involved in this.
                  I would correct the issue now so I could sleep well at night
                    Never assume, a LOT of service/replacement work goes uninpesected unfortunately.
                    Masterplumb's decription is correct afaik.
                      What is "afaik"?
                        Originally posted by Masterplumb View Post
                        What is "afaik"?
                        AFAIK = as far as I know.
                          You can cut a W/H vent into the furnace vent if it's all gravity, but unless it's a higher BTU (50,000+) you can't go into anything bigger than 8". That's the 7* diameter rule. That said, it still shouldn't be coming out the furnace. Have you looked into the chimney to make sure you don't have a bird's nest or something going?
                            Here we go again,forgetting ,It's a big country,with differend codes and amendments.
                            Hundreds of Homes in S.F. have 2 appliances sharing one flue!!!
                              You're right of course. Natl Fuel Gas Code covers venting here.
