Pressure Testing Supply System
  • Pressure Testing Supply System
    When you pressure test your rough in supply system with air, how much if any of a pressure drop is acceptable? Do you leave it on until the drywall is on so that you will know if there is problem so you dont have to rip drywall off later?
    Re: Pressure Testing Supply System
    once required inspection period is passed you're done
