female fittings
  • female fittings
    hello all. i'm looking for copper fittings. i was looking for half-inch female thread by half-inch sweat but with a gasket or o-ring instead of straight thread. i have seen them in cpvc plastic solvent weld but not in brass or copper except for meter nipples. anyone know of a place online? thanks in advance.
    Re: female fittings
    I doubt that such a fitting exists. The gasket would meld when you soldered it on.
      Re: female fittings
      checked my Nibco catalog. No such item exists.
        Re: female fittings
        What are you trying to do?
          Re: female fittings
          pro press has a gasket, and they ask you to remove the gasket when you are going to solder the other end of the fitting. the gasket being an O'ring
          Robert
            Re: female fittings
            hello again. i am not trying to do anything at this point. i'm sorry if my question was misunderstood, i should have said it was hypothetical. the reason i was curious was because i see a lot of fittings in plastic that have the gasket or washer type fittings and wanted to know if such a thing exists in copper sweat or compression one end, instead of sweat or male thread by female copper with a washer on the female side. i know there are other combinations that can be used but for my curiosity i asked my original question. thanks again in advance if anyone cares to reply.
              Re: female fittings
              the coper fip is tapered so they will not need a o ring or gasket
                Re: female fittings
                i know why they don't need an o-ring or gasket. my question, is there one available in copper since there is in plastic? like i said before i was just wondering.............that's all. i'm a curious guy!
                  Re: female fittings
                  I'll make You some. Can You afford them??
                    Re: female fittings
                      Re: female fittings
                      I havenĀ“t seen such fitting, they would be useless.
                      Bathrooms
