Shower diverter--leaking fittings
  • Shower diverter--leaking fittings
    I'm installing a lot of shower diverters in an apartment rehab job.
    My problem is I too-often get a leak in the threaded fittings that screws into the diverter.
    This really sucks because then I have to cut my pipes to remove the fittings to try again.
    Does anyone have any advice on what to wrap/coat the threads with, how hard to screw the fittings in, an easy way to pressure test before completely installing it, etc.
    thanks
    Re: Shower diverter--leaking fittings
    When I am doing MIP's. I wrap 3 to 4 times with teflon, and then a round of Key-Tite
    Nothing gets past Key-Tite!!
    Robert
      wrap with tape then apply the gasola and tighten never had a problem
        Thanks for the advice. I'll try the Key Tight.
        When you say apply the gasola, I assume you mean heat the fitting with your torch?
          Gasola is a brand of pipe dope..
            yes it a a pipe dope i misspelled it, now the correct way is gasoila, great stuff not cheap, use to use there hard set on steam system piping never had a leak, then they produced a soft set about 15 years ago, try it youll like it.
