Pin Holes in PEX
  • Pin Holes in PEX
    About six months ago we get a call from a client that had a pin hole leak in her PEX water line, we tear the wall open and find a cold 3/4" line bent to a 90 for a manifold tie-in leaking about 2" from the manifold. Figure that some how under stress from the sharp turn it may have weakened the pipe and caused a leak even though the pipe was not kinked. Today we get a call from same client saying she hears water dripping in her ceiling, My Partner goes over cuts ceiling open and low and behold another pin hole in the PEX pipe. This time it is in the middle of a straight run. Has anyone else had a problem like this? The house was built 1998 and has city water. pipe is supported with full rap talons about every 2', no signs of wear on pipe just a small pin hole. I thought that this stuff was to last forever or at least my life time!
    ________
    Unitarian-universalism advice
    Mike
    Re: Pin Holes in PEX
    I found a piece of 1/2" Wirsbo in the wall once with a misting pin hole which was almost impossible to see.
      Every time I've come across a pin hole it was caused by a sheet rock screw or nail.
        It's a good chance that if the Pex is defective it all came from the same batch. Looks like the whole system is suspect at this point.
        Cut the bad sections out and send the samples to the manufacturer. If they have a bad roll out there they might want to know about it.
          Anyway you can tell us what brand pex it is??
          Robert
            I called my partner up after reading the replys and asked if he was able to tell me the manufacturer of the pipe and he said that he was not able to tell. I am going to have him call and go back over to see if he can get a name off the pipe. After reading plumberscrack comment i looked into some of the PEX suppliers i have used in the past and see that some come with a 25 year warranty. I just have to see what all they cover and and what the homeowner is responsible for.
            ________
            Crossfire
            Mike
              Wirsbo just paid for a tear out in Wash. state! This is radiant. And this is My familys Buss.
              On another project,there is bubbling on the exterior. They came out and inspected ,and documented. The 1st job was repaired this Month. Don't know the install date. Wasn't their project.
                I've been working with Pex over 6 years and never had a problem as long as I did'nt miss a ring. A few months ago a customer said he had a pin hole leak I figured it was copper, crawled under the house and it was pex. It was spraying in the middle of a run. looked around and saw another pin hole on a pipe crossing a duct line. When I cut it out and took it outside you could see it was caused by rats, my guess from all the rat bait the customer had under his house they were looking for a drink.
                  This is the reason I am investing in pex tools, for all the repairs!!!
                  and maybe some small re-routes or something.
                  Robert
                    Robert ,You made a great point!!!!
                      after reading these threads i suddently got a flashback of the polybutylene debacle!
                        The manufacturer of the pipe is Quest.
                        ________
                        ROLLING A JOINT
                        Mike
                          It doesn't meet the requirements for eligibility in the recall
                          http://www.pbpipe.com/Eligibility/tabid/56/Default.aspx
                            The pipe is not Polybutylene, it is you everyday run of the mill milky white PEX pipe.
                            ________
                            Sc2 replays
                            Mike
                              Quest, we don't have it out here, but from what I have heard, it is bad, bad, bad
                              Kinda like polybutylene was or in some cases, is still
                              Robert
