Garage Bath SF
  • Garage Bath SF
    Adding a toilet Lav.,New laundry tray. Ok to dump washer into tray instead, of stand pipe?
    That's what I found . Removed old double concrete tray,replaced with plastic.. concrete torn up. Never had an inspector complain about this. I'm reusing some of the old C.I. under the slab with new no hub. Still snaps clean! Why not??? Yea, I'll probably get busted!
    Re: Garage Bath SF
    The tub is fine, and 11/2" works also because the basin allows for the water to puddle up before draining.
    Robert
      Re: Garage Bath SF
      What Robert said.
        Re: Garage Bath SF
        What Robert said.
        I can't take much more of this.Did he just hire you?
          Re: Garage Bath SF
          Why not ?? The rest of us did!!!
            Re: Garage Bath SF
              Re: Garage Bath SF
              Oh you guy's are just too much
              Robert
                Re: Garage Bath SF
                the issue lies when the homeowner wants the laundry tray removed and keeps the 1.5'' stub out.
                in the old days, all there was, was laundry trays. as washers replaced the trays, and dryers replaced the clothes lines, nobody was replacing the 1.5'' waste with 2'' lines.
                with the newer hi efficiency washers, the issue is not bad. it's the older 20 gallon top loaders.
                rick
                  Re: Garage Bath SF
                  I would never go with 1 1/2" for this .I went 2" thanks' all
