Kitchen faucet losing pressure
  • Kitchen faucet losing pressure
    After the kitchen faucet has been running for 30 sec., 1 min. etc. it will lose what seems like almost half of it's pressure. Any suggestions on what might be causing this. Does not happen on any other faucets in the house. Thank you.
    Re: Kitchen faucet losing pressure
    Would it have anything to do with timline of the hot water reaching the fixture.
      It sounds like you may have a volume problem but we need to know more info.
      What type of piping do you have?
      How old is the house?
      Is this related only to the kitchen faucet?
        Clogged aerator.
          Could be lots of things. Well pump? Could be short cycling due to waterlogged tank, etc. Seen some Moen kitchen faucets slowly close on their own. Also seen some Moen high arc spouts with poor output.
          Could be a combination of a well pump (IF you have one) and the brand/type of kitchen faucet.
            If it's a glacier bay [ junk ] replace it with a real one!
              It's ALIEN'S,they're diverting the signal from our satelites to induce confussion and mayhem.
                I dunno 'bout you, but I wear my foil beanie in the sanctity of my home....awaiting commands from the mothership....
                  Adam,
                  Don't you ever get tired of being right?
                  The Other Rick
                    Are you sure it doesn't happen at all you faucets? I would check at least 2 locations about 30 minuets after each other as it sounds like your pressure reducing valve might be wearing out. That is if you have one on you system? If not I will have to agree with drtyhands on this one.
                    ________
                    FERRARI 156 F1 SPECIFICATIONS
                    Mike
                      See 24hours later and no response.I told you.Looks like they got another one.
                      I'll start checking the tabloids,do some deep research,see if I can find the most recent drop zone.
                      There may still be a chance for Opie.
                        Appreciate the help every one. Luckily it was not aliens. I took the faucet apart and there was a washer stuck in the high arc spout that I guess would get lodged and slow flow. Got it out works perfvect now. But i do think I saw some green men last night after my girlfriend made jello shots.
