Running Water at Pressure Regulator
  • Running Water at Pressure Regulator
    Co-Worker cannot locate a leak inside his home, however there is a constant flow of water at the Pressure Regulator?
    Re: Running Water at Pressure Regulator
    Hmmmmmmmm. Pipeing in slab?
      Nope, all piping is above the slab downstream of the regulator..
        Ask him to look in the toilet tanks and see if the water level is set to high and spilling into the overflow.
        ________
        MAZDA RYUGA HISTORY
        Mike
          Leaking Irrigation system?
          Maybe he just had it turned on?
          How long has he had the leak?
            Check toilets, RO units, and outdoor faucets.
              you got it older r/o units continue to run and produce waste. easiest thing to do is shut off angle stops to toilets and kithen r/o unit. also check automatic sprinklers for weeping. the water meter should register the amount of leak.
                Thanks Folks, It turned out to be a Faulty PRV.
                THANKS AGAIN!
