Washing Machine Drain Standpipe
  • Washing Machine Drain Standpipe
    Can a washing machine be drained into a 2 inch pipe that is reduced down
    to a 1 1/4 inch drain pipe? The home is on a slap and the 1 1/4 inch drain
    currently exists in the bathroom. Should this setup require a drain vented
    piping as well?
    Thanks for any info.
    Re: Washing Machine Drain Standpipe
    NO NO AND NO ! ! !
    MUST HAVE 2" DRAIN ALL THE WAY TO SEWER MAIN, AND YES IT NEEDS TO BE VENTED !
    NO WAY WOULD 11/4" PIPE CARRY THE LOAD ! !
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
      It could serve a dual purpose.
      Laundry drain - Floor prewash soaker/sudser.
        Around here, you cant put anything smaller than 2" under a slab??
          Nice reply Jerrymac> I like the way you kinda sneeked up on your answer. Subtile as a brick.
            Yeah, he does seem to "beat around the bush" a little bit. He really needs to learn to be more direct with his answers
              Originally posted by JERRYMAC View Post
              NO NO AND NO ! ! !
              I could NOT have said it better ,
              Yea 2" all the way for sure
                Will the main vent pipe that currently exists be sufficient?
                  By the way this is a 50+ year old house ...
                    Kind of like a electrical outlet,I don't know the size or what you got on it.
                      They require us to increase the w/m branch to 3" here to accommadate suds & stronger pumps.
                        I thought that was only if it ties into another fixture, like a kitchen drain. Oh wait they recently changed it again. I'll have to look it up later.
                          Besides the inadequate pipe size, you cannot reduce downstream. The one exception is a 4x3 closet bend.
                            piping as well?
                            Can you say restriction
                            Robert
                              i like to stay at least 10 pipe diameters downstream from the nearest connection to prevent sudsing.
