Sizing Commercial Booster Pumps Page Title Module
  • Sizing Commercial Booster Pumps
    A management company wants to add booster pumps to 3 buildings.
    Each building has a new 2" water service installed 3 years ago
    Static pressure is 60 lbs. read before the backflow preventer.
    4 story building 40 feet high. Top floor pressure should be what? 45 lbs. static?
    There is some loss in pressure though the backflow, right?
    Here's the problem. During heavy usage in the early mornings and evenings pressure to top floors suffer. (Sorry I don't have the numbers) It's so bad some are unable to shower.
    WASA (D.C. Water and Sewer Authority) says nothing they can do to increase pressure. The problem is system wide. Too much new development in this area without the proper infrastructure.
    So my question is how does one go about sizing a booster pump system and who makes a good pump? Money is not a concern here.
    Each building has 35 units all with 1 bath (standard tank type toilets) laundry in basement, no irrigation
    Re: Sizing Commercial Booster Pumps
    What pressure do you want on the first floor?
    Are you going to be able to regulate lower floors if you want more than eighty down there?
      I made a phone call to my pump guy.
      Are you able to go three phase?
      The technology now will allow you to go with Variable Frequency Drive(VFR).It is a far more efficient motor/system.
        Screw the lower floors. It's the top floors that are bitchin'
        Yea no problem. I can make even more money selling PRV's to the condo owners.
        The technology now will allow you to go with Variable Frequency Drive(VFR).It is a far more efficient motor.
        I used to have a pump guy. I wonder where he is I guess you are my pump guy now
        No just single phase. Is VFR only availible in 3 phase?
          O/K 220?
          Riser stack or individual branch stacks?
            220v good
            Riser stacks
              40' @ .434 per foot in height adds to just over 17, incoming is 60.
              Assuming max psi in your code is 80, you could get away with a booster and not have to use prv's on the lower floor.
              I'm guessing your customers just not happy with flow on the top floor, it's just about 43 psi.
                Originally posted by plumberscrack View Post
                220v good
                Riser stacks
                Pick one
                A.Unit risers
                B.fixture risers
                I am assuming they are unit as we think we can resolve through boosting/regulating lowers?
                  You know how it is Ducky. You get a bunch of DINKS with bathrooms bigger than my bedroom. They all wanted champagne ceiling mounted dinner plate size showerheads. The problem only exists during peak usage. All other times it's adequate
                  Pick one
                  A.Unit risers
                  B.fixture risers
                  Unit
                    Unit
                    Oops, I stand corrected, you need a 40psi boost, with prvs all over the place in the first two floors.
                      I only want to boost the pressure when it drops too low. Pumping it up to knock it back down again doesn't seem right to me
                      Feed me... I'm a sponge
                        Unit
                        Best we can do on my end is have a pump number with amps and GPM's tommorrow.It's too late for my loop.
                          Just for the record.The three phase VFD's don't need a tank,just a bladder.The system is digitally controlled to only pump usage.It ramps up based on demand(1 shower or all 35 units) versus full on/full off for 1 shower.
                            I am not disagreeing with dirtyhands on the use of a pump with a VFD. However, a VFD can only ramp down so far. I would look into a duplex or triplex (probalby just a duplex) system with PRV's on the lower floors if deemed necessary.
                            Regards,
                              Both Goulds and Grundfos publish the information you need on their web sites.
