825y
  • 825y
    What kind of test can I do to the 825Y Reduced Pressure Zone Assembly without the FEBCO Test Kit (I don't have any testers) to satisfy the inspector and pass inspection? This is a vacant house, the valve was stolen and the water co shut off the meter and needs the new valve, permited, tested and approved. Any help? Thanks.
    Re: 825y
    You could use any brand tester it does not have to be a Febco. They usually start at around $500 for a cheap one and you generally have to be a Certified Tester to test them.
      Re: 825y
      Thanks Mark.
        Re: 825y
        As stated already, any test kit will work. Just make sure you give a copy of the test results to the inspector.
