I Need Help
  • I Need Help
    3 month ago I bought RIDGID Ridgid 1 HP Submersible Sump Pump. But now I see it sucking water out but Pump is not stoping its just keep running. Even thought there is no whater. I tried to clean the sansor but still not working I need help
    THank you
    Re: I Need Help
    This definitely is an indication of a float switch problem. Not that familiar with the Ridgid pumps, but I have known many pumps with magnetic float switches to have problems. You may consider installing a tethered float switch. If it already has a tethered float switch make sure it is not catching anywhere on the basin. Also assure that this pump has an air vent, or drill a small hole 1/8" on the discharge outlet near the base of the pump (before the check valve) to keep this pump from becoming air locked.
      Re: I Need Help
      It's crap, take it back to home depot and get a zoeller
        Re: I Need Help
        switches are normally a pumps weak link, replace the switch, and hopefully with a better than the factory unit.
