Cash Acme Thermostatic Mixing Valves
  • Cash Acme Thermostatic Mixing Valves
    I was wondering if anyone has ever had problems with the Cash Acme thermostatic mixing valves? Where i work we have had 3 of these valves in the last week that keep going up and down in temperature when u have a tap or shower running and when u go to try to adjust the temperature it seems that the adjuster is seized. Just wondering if anyone has some ideas?
    Re: Cash Acme Thermostatic Mixing Valves
    sounds like a bad batch. It happens. Take em back.
      What is the water heater setting? Needs to be at least 10 degrees higher than where you want your valve setting. I would set it at 140F min.
