I need Help!
  • I need Help!
    My husband and I replaced our bathtub plumbing, including a new plunger drain on the tub. Well when he was putting cement on one of the pipes he apparently had gotten some on the new plunger and now it is stuck to the inside of the pipe. Are there any suggestions other than starting over of what we can put down there that might free up the plunger?
    Re: I need Help!
    I wouldn't begin to work on the plunger in this case without removing the waste and overflow unit from the tub. Then, you'll know whether you can even break it loose. If you can't get the plunger loose and clear the unit, you can then replace it. And if you don't have access to it to remove it, you should.
