Air lines
  • Air lines
    I am going to install hard air lines in my shop. I have decided to go copper or iron pipe. If I use copper can I use Type M?
    Re: Air lines
    Thats fine. Many folks go pvc. Many nay sayers on this. Never heard of a problem ,Myself.
    schedule 80 would be very strong. Use a water seperator. I , myself would be conserened
    with freezing conditions and pvs and possible water in lines
      Re: Air lines
      go to themanufactures web site for plastic pipe. this is a definate no .
        Re: Air lines
        I like steel in a shop. It is very strong, dent and bash proof and easy to modify if you have to. copper is ok, plastic is a no no.
          Re: Air lines
          Copper is the best choice (no worries from rust), steel next.
          Plastic is a definite NO! Unsafe.
            Re: Air lines
            Use some PEX
            Distractions are everywhere, don't lose sight of your dream.
              Re: Air lines
              Black iron with water traps on your drops will work great
                Re: Air lines
                I concur. Copper is OK too though.
                  Re: Air lines
                  I would use galvanized for your air lines, and leave drain downs for the condensation.
                  Galv has proven itself with gas and water here.
                  I would not use black pipe
                  Galv all the way, and it costs less then copper. The only thing, you need a way to thread it
                  Robert
                    Re: Air lines
                    The air lines in my shop have been ther for over 30 years and I've never had rust problems with them.
                      Re: Air lines
                      I've run air lines in Sch. 120 plastic, we threaded it and used threaded fittings, but it was in a chemical plant with a very corrosive environment. We had to get a waiver from OSHA to install it.
