advice
  • advice
    ever time I do h w I have a problem with the union sweet 3/4 it drips not at the sweet at the treads should i put the bass with the flow and the copper against it ,or am i just over tight it drive me nuts
    Re: advice
    Please review your spelling and grammar and retype because it is very hard to understand what you are trying to ask
      Re: advice
      With the right bait, you can indeed catch some sweet bass...as long as you tread lightly.
        Re: advice
        Anywhere you have a brass/brass connection, or a brass/copper connection, be sure to use some TFE paste on the contact (flare) surfaces. This will probably take care of the problems you are having.
          Re: advice
          Wa Wa wa What!
            Re: advice
            Sorry about the grammar . Whenever I use a brass/copper union I get a little leak right at the treads. So i then tighten and it and it didn't' stop ,I some times have to replace the union .I put the brass side to the flow .
              Re: advice
              You must be picking up chinese or korean made fittings. A quality fitting will not leak and requires no pipe dope between mating surfaces.
                Re: advice
                are you positive that you arent getting any solder on the mating surfaces of the union?
                  Re: advice
                  Hmmmmm, I always use a little pipe dope on the mating surfaces of any metal to metal union, whether it be copper flare, black unions, compression fittings. Better to be safe than sorry I suppose. Have seen too many fittings leak without it. Maybe I should be buying from a different supplier.
                    Re: advice
                    Of course you do.
                      Re: advice
                      Originally posted by DuckButter View Post
                      Of course you do.
                      couldnt say it better myself!
                        Re: advice
                        Maybe your not lined up? Are you relying on the union to pull everything toghether??
                        You need to spell "Plumber" right buddy, You Have "Plummer"
                        No solder in the flange part of the fitting either. No overheating also. always let cool before you screw it toghether
                        Robert
                          Re: advice
                          The mating surfaces of the union require no pipe dope or pipe thread to seal the union. The seal is entirely dependent on the ground joint mating surfaces. You may use a drop of oil to lubricate the threads as you tighten the joint. Use of pipe joint on the mating surfaces increases the chance of contamination getting into faucets and appliances and in the case of a gas valve could be disasterous.
                            Re: advice
                            Look...MR...
                            It's "PLUMMAH" where I come from...got that?!?!?
                              Re: advice
                              Just makes me wonder, over the course of 15 years, how many teflon & doped flanges are out there in MI.
                              Maybe I should just be nice, go along with it.
