Kwik Spin problems
  • Kwik Spin problems
    The drain in my tub is clogged and the water goes down slowly. also the water from my sink fills up the bathtub. I bought the Kwik Spin from home depot to unclog the tub drain. Is the Kwik Spin good for unclogging tub drains and if so how do I properly use it.
    Re: Kwik Spin problems
    Do you own a hammer?
    If so, take the Kwik Spin out of the box and beat the hell out of it.
      No seriously. Very light clog clearing capabilities if you have some knowledge of plumbing systems.
      If not, you're probably going to kink the lightweight cable making it useless and unreturnable. That will make you real mad.
        No, I'M WRONG! I thought you meant the Auto Spin. With a Kwik Spin manual spinner a layperson might be able to achieve success.
        Less likely to kink the cable.
          You don't have just a tub stoppage. The kwik spin is not enough to handle this job.
