Leaking shutoff
  • #46
    Re: Leaking shutoff
    i'm with ben, i cut the copper properly to allow for a flush fit to the estucion.
    i can't picture soldering the tens of thousands of angle stops i've done in my new construction days. commercial were typically ips loose key stops and residential were compression stops.
    remember i was good for roughly 400 stops a day, installed and tested. waiting for water to stop dripping and prepping to solder would be down to less than 100.
    there is absolutely nothing wrong with a compression stop. remember the outlet side is either a compression connection or a slip joint connection.
    now if you want to have an angle stop competition at the next roundup, i'll be glad to put that trophy next to the 4 that arrived today
    I never said I was against them. Most inspectors here will not allow them.
    I dont do commercial so your argument about doing 400 a day is meaningless to me. Speed is not really a concern for the 3 that I would install for a bathroom renovation.
    Oh hey congrats on the trophey's but if you want to have a contest lets have one at the round up for nicest looking solder joints, to me thats a contest. Any takers?
    • #47
      Re: Leaking shutoff
      i have seen out here the plumbers use a solder stop with a chrome tube on them
      way back in the old days when i did it i used a solder stop and chromed the pipe so it looks good
      the only time i went close to the wall was on a pedestal sinks thats how we did it when i had to walk to the jobs in 3ft of snow
      • #48
        Re: Leaking shutoff
        I'm out of the contest on the best looking solder joints. Some of mine look like Stevie Wonder did them after about 5 espressos.
        • #49
          Re: Leaking shutoff
          rick uses pro press
          • #50
            Re: Leaking shutoff
            Puss Press.
            • #51
              Re: Leaking shutoff
              Out of the thousads I've seen 2 break out of the box,the back blows out(bad casting).You can feel it immediately,feels like when you strip a bolt.It tightens real easy all the sudden.
              Good point though
              adam me too
              i had issues with washing machine valves. there was a brand we used at 1 time that was a combination compression and mip. those were the bad ones and i had our shop change brands.
              • #52
                Re: Leaking shutoff
                I'm soo clever ,It hurts. I have a great shop. Carpentry and welding. So nice to be able to weld steel,S.S. allum. I re-inforced one of My ferral pullers,to the Max. I call Her MAD MAX. Ist nasty old pull,was a disaster. 5000 ft lbs of Irish forarm,and it's movin. You guessed it .Extruded that copper down about 3/16 in diameter. Cut and solder
                • #53
                  Re: Leaking shutoff
                  Originally posted by HVAC HAWK View Post
                  rick uses pro press
                  when ever possible now
                  Puss Press.
                  because i've invested the money in 5 machines and 2 sets of xl jaws, would make me the wise man.
                  i'm there and lets make it more interesting
                  vertical joints, with no glove or rag. possibly 2'' or 6'' if your buying
                  i have plenty of 2'' , 2.5'' couplings, and a handfull of 3''-6''
                  • #54
                    Re: Leaking shutoff
                    Just jealous I can't use one.
                    • #55
                      Re: Leaking shutoff
                      I have to buy??? You are the one that was doing commercial work making all that money by saving time doing 400 angle valves a day
                      No glove or rag, you're on.
                      • #56
                        Re: Leaking shutoff
                        i have done joints and wipes the drips with my fingers
                        and i have seen how pro press does save time ,the plumber is using one on a large job and it is nice
                        • #57
                          Re: Leaking shutoff
                          I accept that challenge.
                          • #58
                            Re: Leaking shutoff
                            that was when i was working for a company. they were making the money, i was making wages
                            i'll bring the fittings, the pipe would be hard to pack
                            • #59
                              Re: Leaking shutoff
                              Upto 6 pages on this already
                              I got it done today - took less than a minute. The old nut came off easily, the threads matched and it was easy to work on since the sink has not yet been installed.
                              • #60
                                Re: Leaking shutoff
                                Engineers can plumb!?
                                Good Job!
