Galvanized Pipe For Natural Gas?
    Re: Galvanized Pipe For Natural Gas?
    I know you don't wrench on the threads.
    Proud To Be Union!!
      Oh, then why this advice:
      There's no spot for your wrench, meaning your wrench will tear up the threads, and probably leak.
        I was just stating.
        Proud To Be Union!!
          There is no visible section of pipe at the end of each taper to keep fittings from bottoming out on each other.
          Anyway, this makes sense. However I have never had a close nipple bottom out before that I recall. They always reached proper torque before the fittings touched. Of course I rarely have used them, usually I use 2" nipples at the shortest.
            I forgot bushings. The standard is in the National fuel gas code. I'm not sure if it's in the upc or not.
            What I heard years ago on close nipples was that because the entire nipple is threaded there is an insufficient amount of steel and they can rust through.
              Agreed. For the same reason, its states in our code that if using a bushing, you MUST reduce more than one pipe size.
              West Trail Mechanical Ltd
              www.westtrailmechanical.ca
