washing machine drains, water in toilet will gurgle.
  • washing machine drains, water in toilet will gurgle.
    Hi,
    > > Sure would appreciate advice on this plumbing issue.
    > > In my downstairs utility room, we have a washing machine with a toilet
    > > (and sink) a few feet away.
    > > When the washing machine drains, the water in the toilet bowl will
    > > gurgle (you can see the water move and slosh around in the bowl) and
    > > usually most of the water will drain out of the toilet bowl by the time
    > > the washing machine finishes draining.
    > > If you try make the mistake of flushing the toilet while the washing
    > > machine drains, the water in the bowl rises to the top and comes close
    > > to overflowing. Just starting having this problem tonight. Also my husband has been using lots of toilet paper due to a medical condition lots of toliet paper piles up in toliet then he flushes later. But as of today he will start putting toliet paper in a plastic bag and tossing it in the trash he is a Cancer survior but with the side effects he uses lots of toliet paper from excess saliva. Please help Thanks Sandy77
    Re: washing machine drains, water in toilet will gurgle.
    Originally posted by Sandy77 View Post
    Hi,
    Definitely sounds like a partially plugged drain. Time to call in the professionals on this one. Tissue paper on its own will usually make it out. There may be underlying issues such as roots, cracked pipe, backpitch, etc.
      Partial main line clog.
      Hire someone to clear the obstruction, a professional drain cleaner or licensed plumber that does drain cleaning.
      $200-$480.45 depending on your area.
        Very sorry to hear of your spouses condition.
        Sounds like a paper clog/restriction to me. Being it drains but slow, it sounds like a restriction. Try to avoid the paper usage as much as possible and if it continues you might have to call a local reputable plumber or drain cleaner.
          I would not play russian roulette with the yellow pages. Get a recommendation on this one.
            Genaral contractor is leasing a suite on the second floor of our 24 story.W/C is full of suds and glugging away.
              Bad Plumbing.
                Dumb question probably. Who did the plumbing?
                  Bad Plumbing.
                  To say the least.There's more.Don't want to be the one to start drift yet.
                    Ok. I'll start the drift. What else is there?
                    Left a brother hangin'.
                      Hi,
                      If you are on a septic tank and haven't had in pumped in the last five years...get it pumped.
                      If not, then call a professional drain-cleaner to cable the main sewerline. (and possibly have it video-inspected if you can afford the extra cost)
                        i tell all of my clients, "you should never put anything in the toilet except human waste abd the LEAST amount of TOILET PAPER possible. no kleenex, paper towls, feminine products, q-tips, cigarette/cigar butts, dental floss or anything. if you do you will be calling me sooner than you think"
                        steve
                          I feel compelled to correct you...I'd say she could expect to pay as much as $480.46.
                            The penthouse suite has four patios,at least two of them flood the vallet guys out right in front of the entrance of the building
                            when I was running water out onto the main drains.
                            The building's original plumbing contractor has got the mains and overflows crossed.Every time it rains they have to rig up some kind of micky mouse garden hose contraptions on the overflows in front of the entrance.Can you imagine spending millions on your shell of a unit and not being able to washdown or water plants on your patio?
                            This guy has a license...Yank it till he starts putting in plumbing like it means something!!!!
                              I'm sure we could find someone willing to double it.
