Plastic Gas Line
  • Plastic Gas Line
    What is the learning curve with this product? How are fittings connected to tie in to black pipe?
    Looking at the potential of a gas well on our property.
    Re: Plastic Gas Line
    They make fused transition fittings.
    it is easy to learn for most.
    You are refering to PE heat fusion yes?
      i need more pork on the fork,your in the concept phase ? well heads in my neck of the woods #5500
        we use a plastic coated gas line, called yellow jacket. Easy to assemble with compression fittings that has a female thread to go to black iron pipe. depends on the authority haveing jurisdiction though
        if u cant bedazzle em with briliance, baffle em with bulls&*t
