back to back toilets
  • back to back toilets
    do you think there will there be any venting or vacuum problems
    if the 2 toilets are installed back to back with a double combo wye
    with one 4" vent
    Re: back to back toilets
    what code is that mister ?
      philadelphia single stack with an ideal bend on the
      bathroom group
        nobody's hipped me to that lingo dude
          Tie the Lav. line into the tub line and use a 4" double san. tee.
          Not combination.
            wont a double san tee have more of chance to create a vacuum
            than a double combo wye
              No.
                From what the drawing looks like, it will be fine. 4" vent is more than sufficient for two bathroom groups. If the toilets are blow out type you can not use a double san tee.
                  The best thing to do is ask the code official in your area before doing the work so that you have to only do the job once. sanitary tees are going to vent better than wyes but you have to know what kinda toilets that are going to be installed to see if it will be permitted . at least by our code
                    thanks for all your answers so far
                    the toilets are regular toilets not pressure assisted or blow out type
                    so it seems like the double san tee is better
                      good luck when it comes time to snake/ auger that back to back toilet with a san tee.
                      a figure 5 or a twin figure 6 with baffle and cap the top of the riser, would be a better choice.
                      you can look up these fittings at www.tylerpipe.com
                        Oh shoot Rick, let him do it his way; when it backs up it'll be the perfect opprtunity for you to haul the k-60 up to the roof vent.
                          thats why i am asking for your opinions...so i dont have any problems later
                          Rick...i cant find them fittings on that site
                          do they have a differant name or can you post a pic
                          and a drop head auger would not work on a double san tee?
                            What's the difference between these and a double wye 1/8 bend? Wouldn't these fitting cause a venting issue?
                              1 question on the drawing should there be a vent on the lav and the tub
