gap between two parallel water pipes
  • gap between two parallel water pipes
    Is there a minimum gap requirement between two parallel water pipes? thanks
    Re: gap between two parallel water pipes
    no, but make sure you leave room for hot and possible cold water insulation.
    4''- 6'' on center is a good spread for 1'' and under pipe.
      enough space to get a ridgid # 15 cutter between is nice
