Delta T/S Trim
  • Delta T/S Trim
    Does anyone know where I can get Delta T/S Trim in Brushed Nickel or Stainless for the old type T/S valve? Before they went to the universal valve.
    I have installed it before but am having trouble finding it now. I think (not looking at it right now) I need it with the valve mounted diverter. Single Lever.
    Thanks.
    Re: Delta T/S Trim
    where do the screws go at 2 o'clock and 8 o'clock? try here
    http://deltaparts.faucetdirect.com/i...facturer/Delta
      Re: Delta T/S Trim
      Thanks for the tip. The trim I was looking for has been discontinued I'm pretty sure. So.....
      I installed a new one today that was a PAIN for me!
        Re: Delta T/S Trim
        Why was it a pain? Just curious. Bad access? Plaster walls?
        YourHomeContractor.com - The Trusted Online Community For Homeowners and Contractors.
        Plumbing Reviews
          Re: Delta T/S Trim
          There is an outfit called Trim to the Trade that has a lot of old style trims in a variety of finishes.
            Re: Delta T/S Trim
            Behind mudbed/lathe tile that was up to the screwholes on the valve. Insulation up to it also. Boards/backing tightly against the pipes and the supplies in concrete. Had to saw pipes, unsweat fittings, & then "wish" it all back together.
            In short, tight everywhere and I didn't remove any tile or drywall on the backside to keep my customer happy.
