Well Casing
  • Well Casing
    I was wondering what if anything should be done as maintenance on the part of the casing that extends above ground?
    Re: Well Casing
    Nothing needs to be done to the pipe that extends above grade.
    Proud To Be Union!!
      Re: Well Casing
      Shouldn't be too much other than keeping the immeadiate area free from overgrown grass/brush/weeds/etc and that the head is intact/secure so as to keep critters and bugs out.
      http://www.cdc.gov/ncidod/dpd/health.../wellwater.htm
        Re: Well Casing
        Well, you might as well tell the guy how to tie his shoes...
        I figured that'd go along with common sense.
        Don't piss near the well head either.
        Proud To Be Union!!
          Re: Well Casing
          If it is in a location where damage could occure you could put up some type of barrier so one does not hit it, but do not block it in such a way that you can not easly work on the well if needed.
          If it it is rusting I would paint it, or use a cold galvanizing compound, if it is plastic I would probly do nothing to it, or paint it with latex paint so the sun does not work on it with the UV light,
          but normally nothing is done to the casing that is above ground unless one has a problems or wants some type of beauty treatment.
            Re: Well Casing
            I can see you've come a lllloooonnngg way.
              Re: Well Casing
              I like when folks build those cutsey little old timey well covers with the bucket and rope. Then they plant flowers all around it and in general make it a pain in the *** when it's time to pull the pump.
              You might paint it like a barber pole for the fun of it
                Re: Well Casing
                On a similar note...I hate homeowners that decide its a smart idea to stack 500 pounds of junk all around the water heater, and then not move it when they call for service.
                  Re: Well Casing
                  I went to a call for a leak on a kitchen sink once and I'm not exaggerating when I tell you that there was plastic containers and lids from the bottom of the cabinet to the bottom of the sink. From side to side and front to back.
                  The whole history of Cool Whip in that S.O.B. I think one of them had Andy Griffiths picture on it.
                  Maybe I'll send it to you next time Carl.
                    Re: Well Casing
                    To continue b!tch!ng about access problems...It seems almost every house I go to lately has the main shut-off valve in some nasty, dirty, spider-infested crawlspace. I don't think I have actually touched a main valve in months...I just go straight for the meter pit in the street and shut it off at the city water meter with my meter-key.
                      Re: Well Casing
                      Yeah until that valve breaks then you'll stop doing that too
                        Re: Well Casing
                        Never happened in 11 years and hundreds of meters....those meter valves are pretty solid. I have had maybe one or two that was in really bad shape and I recommended replacing it.
                          Re: Well Casing
                          It'll get you sooner or later. Trust me.
                            Re: Well Casing
                            I don't understand your point, what if the main valve has to be replaced, then you HAVE to shut it at the meter?
                              Re: Well Casing
                              Never had one get me....but it might. I'm friendly with the local water maintenance guys so they can reset a yoke & meter without too much hassle.
                              I understand some areas of the country raise he!! if you touch the meter. Not that way here.
