cross over
    Re: cross over
    in a multi unit building (2 or more units) every fixture has to have a shut off. very few multi story buildings have individual services to each unit.
    angle stops count as a shut off. tubs and showers require an integral stop.
    the only fixture that seems to sneak by is a laundry hose bibb. they tend to look at it as a stop. but truthfully the hose bibb will need new packing or replacement.
    as far as being able to shut the valve down the road. i find that if nobody has messed up the screwdriver stop with a bad fitting screwdriver. i can usually get them to turn and shut off. honestly i have more issues with angle stops shutting off than a screwdriver stop.
      Re: cross over
      I don't generally use them unless it's a multi-family building. I'm always surprised when I do use them and they actually work!
        Re: cross over
        Originally posted by Masterplumb View Post
        NY state code says you must have integral stops on a shower valve. Why wouldn't you want a shut off on every fixture?
        Does it have to be an integral stop by code are can you still put in ball valves if there is an access panel ?
          Re: cross over
          I couldnt see an inspector shooting you down for a ball valve instead of an integral stop. So I will guess and say that would be acceptable. Good Q.
            Re: cross over
            Just passed inspection on bathroom , I had to ball valves feeding hot /cold in bathroom. AND CAPPED WC and sink .will put shutoff today .
