cross over
  • cross over
    I moved a water heater about 2 feet from where it was .Now i am getting cross over in the kitchen not up stairs . I also rough in a new bathroom in the basement about 3 feet from the water heater . They never had this problem before ,can it be the old hot water heater(about 30 years old) is to high temperature .and can be crossing over . or do i need to put a check valve on the line , also the water is about 3 feet away from the hw .The inspector will inspect the bathroom not the wh .next week sometime
    Re: cross over
    We use copper flexes in E. Quake country. Ialways loop My cold, so the hot doesn't travel
    up and out
      Re: cross over
      Just moving a water heater does not cause crossover. To be more specific: Since you moved the W/H, you ? are getting hot water out
      a cold water faucet? Did you move any tees, or just extend existing
      lines?
        Re: cross over
        Could be that the tub/shower valve that you roughed in is on, and the spout/head nippels are capped. Cross over city. Make sure the mixing valve is off and see if that helps.
        Greg
          Re: cross over
          I agree with glkearns.... good catch!
            Re: cross over
            Yup, good catch. The new Delta has a cap, you pick the cartridge later with the finish. Causes a crossover. I just read "moved the W/H" and scratched my head.
              Re: cross over
              Just close the integral stops then.
                Re: cross over
                No integral stops. Guessing but alot don't have them. I like it when they do.
                  Re: cross over
                  excellent catch <It is a delta with the cap .. thanks all
                    Re: cross over
                    Integral stops = code
                      Re: cross over
                      Which code?
                        Re: cross over
                        Which code?
                        Not NPC......and I'm pretty sure NY is NPC like KY is.
                        Every integral stop I've found on shower faucets were "after" I had already turned the water off, and most all of them could not be turned off due to calcium buildup.
                        Of course, you could back them out and clean them for the next time....
                        I'm the kinda guy that one valve shuts it all down.
                          Re: cross over
                          NY state code says you must have integral stops on a shower valve. Why wouldn't you want a shut off on every fixture?
                            Re: cross over
                            Ahhh, it's a good idea, not saying it isn't. But they are concealed/hidden and most times on a Delta or Moen you can do a full rebuild without removing the cover plate.
                            That goes in line with other valves as well.
                            In my experiences though, those stops never provide a permanent seal to shut off water. It's like any other valve that was installed initially and not touched for years before being used.
                            Most of the 600 series Delta shower valves I run across had the integral stops.
                              Re: cross over
                              I agree but the code is the code.
