Looping water run
  • Looping water run
    Hey all!
    Here i come to you againg for wisdom and advice!
    I want to install a hot water recirculating pump. The 2 fixtures I want attached to the pump are separate (not on the same line)... is it possible (allowed) to connect them together as in the diagram I've attached?
    Many thanks in advance!
    Re: Looping water run
    The water is going to choose the path of least resistance.
      Nice to see you're still alive. I thought I was going to have to pull a favor and investigate your dissapearance.
        Thanks Ben
        Amazing Summer!!!
          That's what i figured but wasn't sure... i know that the water can't go back to it's own pipe... or another pipe upstream...
          thanks for ur quick answer!
