Water pressure off the chart!
  • Water pressure off the chart!
    My house is 20 years old. It goes through washers and seals like my kids through sugar.
    I just replaced the wading and grommets on the washing machine cold water inlet, and master bath washer and grommets (for the 10th time) and got the brainstorm to check the pressure.
    The gauge pegged at 100 psi max reading and was still climbing. I am including a picture of the meter.
    Is this extra piece a regulator and how do I adjust it down? The neighbors meter doesn't have the extra module. Of course it rests right up against the meter box so I am sure will pose problems.
    Re: Water pressure off the chart!
    i don't know what the that other thing is..?? maybe someone else would know.. i would just install a Pressure Reducing Valve on the main right before it enters your home ..
      I don't even see the "other" thing?
      All I see is a water meter
      You probably just need a pressure reducing valve and an expansion tank on your water heater
        Maybe that other thing is a screen. Get a plumber to install a pressure reducing valve. Sounds like it'll pay for itself.
          That is not a pressure reducing valve!! Have you plumber install one and go to bed with peace of mind!
            Get a prv installed in the home and you wont ever change the washers again--its a pretty easy job-wont take very log at all
              i am guessing it's a double check valve.
              100# is not much over the 80# max. we're allowed without a pressure regulator.
              chances are you need a pressure regulator and an expansion tank to compensate for the thermal expansion from the water heater and the possibility of having a closed system as the double check doesn't allow for a thermal expansion bypass
              the only way your pressure will keep going up is thermal expansion. simple way to test is to put a pressure gage on the hot hose bibb and close the cold inlet to the heater. turn the thermostat up to cause the burner to kick on and watch the gage go up. at 150# the pressure relief valve will open. you can then check the cold water pressure from a hose bibb or laundry bibb. only the hot should have risen. not the cold.
              make sure to lower the temperature back to normal and open the cold water valve.
                To me-this is a pic of a standard water meter box--thats it
                  RICK--HOPEFULLY NO HOMEOWNERS TRY THIS AND FORGET TO OPEN VALVES DUE TO BEING SIDETRACKED AND HOPEFULLY THE RELIEF OPENS OR------
                  IF THEY FORGET--REMEMBER THE PICS OF THE TANK THAT SHOT A BLOCK AWAY????
                    MAYBE IF I TYPE IN CAPS AND BOLD PRINT, THE BLIND CAN READ MY LAST SENTENCE.
                      We don't have the same EXACT water meter in our area,but close.
                      The difference is the direct Male street supply on one end and male house end. This one has a lower manifold and at the top of picture ,maybe house side, I see what appears to be a
                      pressure adjust knob. I'm guessing. Picture isn't that close. Someone in that area will tell Us ,I hope
                        much better rick
                          Thanks for all the responses. I reattached the picture with a description to show the module I'm referring to. It looked to me like the center bolt is a lock bolt that will allow the outer hex piece to be adjusted. The outer hex piece is against the box and won't turn without some space.
                          That is if this was some kind of regulator. Seems from the responses that a PRV is what I need.
                            I believe the "outer hex piece" you are referring to is just the service yoke.
                              Is it possible to maybe get a better photo and brush off the crud laying on top so we might see a model number or name or something to help ID this. You could always call your water dept and ask them what the heck it is.
