Help with gas pipe
    Re: Help with gas pipe from the great oz
    OK M. P. You can come out from behind the curtin now!
      Just off the phone with another member, NO guys...it ISN'T ME!
      I just got in, loooong day.
        Weasel Boy, you are a real Weasel.
        Now get the **** outta here.
        Proud To Be Union!!
          We've created a monster.
            Someone is obviously trying to play into my DIY stance, I have a sense of humor..got a laugh from it.
              Originally posted by Weasel Boy View Post
              I am installing a gas hot water heater and I heard that the gas company uses a lot of plastic pipe so I went to Lowes and got 3/4" pex pipe and some quest fittings to hook the gas from the meter to the tank with, but I can't find a fitting that goes in the meter.
              as much as i would help most people, this is not the time to do so.
              i'll give you a quick lesson on gas pipe.
              the gas companies and licensed plumbers/ contractors use a product designed for underground installation.
              it's a hdpe pipe. it's yellow and is not available to unlicensed/ uncertified people. i rather doubt you would qualify as a licensed, certified installer of this product.
              now what you might be looking for is csst gas pipe. this too requires the proper licensing and certification.
              what is hdpe and csst
              if you're a real tradesman, you'll know this and right from wrong.
              so you see, i do use discretion with giving out advise
                You should be able to get a reducing rubber fernco coupling to attach to the gas meter. The large end will go over the gas pipe connection and the smaller end will go over the pex fitting. If you tighten the fernco clamps properly, you'll be fine.
                p.s. The above advice is completely sarcastic and should not be followed by anyone. Attempting your own gas work without the proper knowledge, licensing and local permits is illegal and can result in devastating property damage, severe bodily harm, or even death.
                • #23
                  Silly real estate developer, weasels don't run pipe!
                  • #24
                    I feel like I just left a high school DARE play.
                    • #25
                      Are you out of your mind Carl? Fernco's on a gas line, get real. You know he should be using Sharkbite gas fittings.......
                      The Other Rick
                      • #26
                        I like the fernoc idea. quick, cheap and adjustable. All you would ever want in a plumbing fitting.
                        • #27
                          So thanks for making fun of me. I'm just trying to get this hot water heater running. Are you all saying that I can not use plastic pipe for the gas? I do not know what "csst" pipe is, but I'm pretty sure it does not take a rocket scientist to use it. I have found that most plumbing is pretty easy. I would maybe call a plumber to do it but most of them will not come out when I need them and then they charge an arm and a leg to do something that is really simple. You try to get a good plumber in Boston sometime.
                          Show Me The Money
                          • #28
                            I am trying, really trying to be civil here but I have to warn everyone that I'm inches away from either a Psycho-Rant or an aneurism, which ever comes first.
                            • #29
                              weasel boy, honestly everyone really thought you were just pulling our leg as the question you posed was so off the wall dangerous.
                              if you are for real, then you really need to hire a licensed plumber.
                              sure getting the pipe from point a to point b is not rocket science, but doing it properly, safely, and to your local code is closer to rocket science than to clueless
                              if you do what you first posted, you will end up blowing up the house sooner than later. i doubt you want that
                              the only real advise i think you will get at this point is to hire a licensed plumber/ contractor.
                              the original question was so far off, that no one is going to take you serious as a knowledgeable diy'er.
                              sorry.
                              • #30
                                Thank you Rick for at least not being so ascerbic as the others. I can understand your concerns but as I said, I need this done by tomorrow for an inspection and there just is not enough money left in the budget to hire someone. Can I use copper pipe?
                                Show Me The Money
