Dry Pack
  • Dry Pack
    I running a 3" cast iron pipe into a concrete lift station with a 4" cored hole. I heard to seal the connection I should use "dry pack and wrap" does anyone know this method or have any ideas about what i should do?
    Thanks
    Re: Dry Pack
    dry packing is similar to rat proofing.
    i assume this is a vertical pipe and doesn't need to be water tight.
    wrap the pipe with 10 mil tape and mix up a sticky mixture of cement and sand. i prefer plastic cement.
    now we typically use 3m fireproofing caulking.
      Re: Dry Pack
      actuall it is a horizontal pipe and needs to be water tight.
        Re: Dry Pack
        I would refer either a "kor-n-seal" wich will allow a little movement if the tanks settle (http://www.npc.com/products/pipe-con...SSPEC05-06.pdf) or Link-Seals (http://d2858181.u85.securedc.com/pdf/sub_ls.pdf)
          Re: Dry Pack
          You can use non-shrink grout but i would rather see either of my above options!
            Re: Dry Pack
            Thanks I think this should do it as long as if will be able to get one.
              Re: Dry Pack
              Any precaster should have them in stock, we use the kor-n-seals almost eevery sewer manhole that goes in the ground
                Re: Dry Pack
                you may have to core drill your hole bigger than 4" though, possibly 8", but i want to say it is 6" or 7"
                  Re: Dry Pack
                  Wrench ,good info. What's Your best practice in this situation. New concrete found. going in.
                  4" plastic ABS passing through concrete. clean out extension travels up 45 degree angle
                  to grade. Can't have ground water follow drain in! Thanks' Tool
                    Re: Dry Pack
                    Tool, If you didnt pour the foundation yet try this:
                    http://www.a-lok.com/pdfs/ZLokCastInBoots.pdf
                    Otherwise go with the Kor-N-Seals
                      Re: Dry Pack
                      Wrench,I'm in the permit stage. I'll go with the z lock boot. Looks great,and I'll pass this info on to friends . thanks' tool
                        Re: Dry Pack
                        we just set a man hole with about 20 pipes coming in and they used the Link-Seals
                        i hope it works
