Cpvc glue on angle stop leaks
  • Cpvc glue on angle stop leaks
    I RECENTLY EXPERIENCED A FALIURE OF CPVC ANGLE STOPS DUE TO TOO MUCH GLUE OR POSSIBLY BAD PLASTIC INCERTS.
    HAS ANYSONE SEEN SIMILER FAILURES?
    Re: Cpvc glue on angle stop leaks
    Never had a single problem with them. I am not real fond of the rubber seal, but don't like the threaded stops either. I typically try to stay away from CPVC all together though.
      What exactly was the failure ?
