Plumbing vocabulary
  • Plumbing vocabulary
    Hi experts, I'm tearing my hair out with a translation from Swedish to English about relining pipes.
    Is there a word in English for the following:
    "Name of the part of vertical pipe that deviates 90 degrees from standing to lying placement for example in a floor or up at the roof and after at least 0.3 meters deviates 90 degrees again to a standing placement." {'branch'?}
    "Similar to above but deviates with 45 degree bends instead of 90 degree and changes the placement sideways by 0 – 0.5 meters on the standing pipe."
    Also, is there a slang term for horizontal pipe in bathrooms?? In Swedish it's called "frogs."
    I really appreciate any help you can give. I don't know where else to turn!
    Grateful lady in Oregon
    Re: Plumbing vocabulary
    katlyn, is this you sounds like a trick my buddy would pull since he just moved to oregon.
    is the word you're looking for called a "riser"
    typically on repipes, you can do the horizontals and then do the risers.
    horizontals are typically the lines under the house/ crawl space/ basement.
    the risers are the verticals that go up into the walls.
    steve, is this your coming out
      No, I'm not either of the folks you mentioned, but I'm grateful for the help!
      Kati
