sump pump switch
  • sump pump switch
    Which sump pump is better? One with verticle floater switch or One with the Diaphragmatic switch.
    Re: sump pump switch
    Don't have any failure rates to tell you which would last longer. The vertical ones are simpler for alot of people. Preset, put in the pit. The mercury switch ones allow you better control of drawdown cycling.
    EDIT: I don't think I'm familiar with the term "diaphragmatic". If that's what's on the Ridgid pumps, then I would say they are less reliable.
    Check back. More experience might chime in later.
      I am comparing RIDGID SP-330 and SP-330D
        Check your PM?
          Diaphram or 'pressure' switches on sump pumps are junk. They last a year or two and then you find yourself replacing them with floats.
