To strap riser pipe or not?
  • To strap riser pipe or not?
    Hello,
    Can anyone tell me if the water riser pipe on the picture needs to be secured or strapped? If it's not strapped, would it cause problem/water leak in the future? If I do need to secure it, can anyone suggest on how I should go about in doing it.
    here's the picture of the bathroom when it's being constructed.
    http://i231.photobucket.com/albums/e..._2/mtoilet.jpg
    Any suggestion would be much appreciated. Thanks a lot.
    Re: To strap riser pipe or not?
    No
      I would strap the water stub-out though.Hold-rite makes a sweet adjustable stapping system.The sliding galvanized channel type.
        No
        once again no
          once again i agree
            Don't forget nail plates.(waste and water)
              Is that an air chamber I see? Waste of our precious copper IMO
              If that flange is attached to the subfloor it's probably too low. With cement board and tile finished floor will be above top of flange.
                Pardon my ignorance but what is a water stub-out?
                Thanks to everyone who responded. I appreciate it.
                  toilet supply
                    Which plumbing code is this under?
                      it is in the upc code. under strappen down,and workman ship
                      you really should not be playing with your dads computer, without his permission!
                      I like it like that !
                      and, It's like that now!!!!!!!!!!!!
                        Killertoiletspider and Toolaholic are under the same Chicago/San francisco Mafioso that requires that waste of copper.
                          you really should not be playing with your dads computer, without his permission![/quote]
                          Have no idea what this means.
                          Thanks Adam.
                            Back to the original question, If you pluck it like a banjo string, does it rattle or knock against wood ? Does it feel loose in your opinion?
